CNC Machining Blog
Is High Speed Machining The Right Choice For My Shop?
Posted by Mike Cope on Fri, Nov 01, 2013
High Speed MachiningWhen we hear the term "High Speed Machining" (HSM), most people associate it with mold making, but what people fail to realize is that this technology is being used effectively by shops of every kind to positively impact the bottom line...and isn't that what everyone wants???
Although it's true that the die-mold industry was the first to incorporate HSM technology - and to put it to good use - but if you think about what HSM really is you can easily begin to see opportunities in almost every type of manufacturing. Basically, anyone who needs to remove large amounts of material quickly should be considering how HSM could help them become more productive...and who doesn't fall into THAT catagory?
Depending on the complexity of your work, you can expect to see an increase in productivity somewhere between 40% and 70% - especially if you are doing a lot of pocketing. Today’s CAM packages are using HSM algorithms to produce toolpaths that will help you get the most out of both your machine tool and cutting tools.
To see what HSM could mean for your shop, click on the link below to download our interactive High Speed Machining ROI Worksheet. Simply plug in the numbers that make sense for your particular application, and the worksheet will show you the results!
If you want to learn more about HSM in general, you can read my blogpost from January for more information: http://blog.hurco.com/blog/bid/214906/High-Speed-Machining-it-s-more-than-just-a-faster-spindle
Download The High Speed Worksheet
Tags: NC / G-Code Programming, Milling, High Speed Machining, CAD/CAM / Post Processor, CNC Control & Software, Manufacturing Industry Insights
Subscribe via E-mail
Follow Hurco
